ICS Bug Reports
I am having issues with the automatic brightness control ! :-(
Same here
Also,I think it it's dumb that on the home screen, the search bar is permanent, even though the search key is right there on the bottom.
Sent from my Viper 4G LTE on the "coming soon" network
Same here
You can turn off that search bar...just disable google search app
Sent from my LG-LS840 using Tapatalk 2
Well then I'd lose the soft key too... good thought though
Anyone else getting a lot of force closes?
Sent from my LG-LS840 using Android Central Forums
No force closes here. Sprint id closed a free times, but it stopped
Anyone try the new fonts? They even show up on the Swype keyboard. One looks like the Simpson's font, but it got annoying
sprint id f/c a lot when in play store.. unistalled it using titianiumbackup. then unistalled the google bar at the top.(phone seems alot faster now without sID)
my brightness control has some hickups. but only when i push the brightness button. have to go into the settings and reset it.
i use power amp for music. still works fine but every now and then i hear a skip like its processing or something.
my biggest cripe is the stupid word bubbles for texting now. Liked the gb style much better. looking for a theme or some way to change back or to something else. any advice for the texting?
I am having this same issue. The only way I can get mobile data to work is by turning put the phone to CDMA only mode. Did you figure out a way to fix this?
I have an interesting bug. I did the manual update, and ever since I have not been able to complete a speed test while on eHRPD. In order to complete one, i have to go to CDMA only. Anyone else having this issue?
Sent from my LG Viper 4G LTE LS840 using Tapatalk 2
try updating your device profile in cdma and then after that completes turn on your 4g and see if that resolved the issue
New bug: the phone keeps reading the sd card over and over for minutes at a time, and then it goes away for a while. I notice out because it comes up in the status bar.
Is this because the new software is too fast for my cheap sd card? It is a SanDisk, class 4 I *think*
my advice is too pull everything you want from sd card and store it on your pc and then reformat the sd card using your device and then put whatever back on the card and will notice after the reformat you will see alot of new folders on the sd card now
No. I tried the un-brick method and won't be back into an eHRPD market until this Saturday. What area are you in? Maybe you can downgrade back to Gingerbread and re-update with a clean install and see if that fixes it.
I am in the Chicago area and EHRPD is common. I will try the unbrick when I get a chance and let you know.
Ok. Let me know. I had the problem in 3 different Sprint markets over the weekend: Vegas, Riverside/San Bernardino, & Los Angeles, so I know it's not just one area.
I tried this, but it did not work.
I have tried turning off Sprint Optimizer, as well, changed profiles in the other
modes, and still not working. I will be in a 4G area in an hour and will see what's up there.
Wonder if this is why I did not receive the Sprint notification that the update was available?
UPDATE: I am in a 4G area and it appears to be working fine on the LTE network. I don't know if I will be able to do the unbrick method and try the manual ICS update again until next week, but for now, I will have to get accustomed to switching back and forth between those settings, if I need 3G connectivity.
Mine worked for LTE too on Saturday night. Strange. I'm taking my phone to Sprint this week, and have them test it out.
Sent from my LG-LS840 Viper 4G LTE using Tapatalk 2
In my office, I have strong 4G connectivity... oddly right outside my office, it goes into EHRPD. From what I noticed, I get a very slow connection on EHRPD, where it seems to let little bits of data through at a very slow rate (i.e. twicca updates as I scroll down the list or the occasional email).
I suspect that the slow data rates on EHRPD are causing other apps to timeout before actually getting enough throughput to deliver the necessary data. Still an issue, but thought I would try to summarize what I have found. Please update if you find anything out from Sprint.
Mine has been turning wifi on randomly other than that no bugs that I've come across any ideas on possible fix for this?
That is am easy fix out I'd the connections optimizer in the wireless settings, bring up system settings, under wireless and networks press more then scroll down to mobile networks and press it then the connections optimizer is in there just uncheck the box
That's probably not a bug, but most likely the Sprint Connection Optimizer trying to get the phone at the "best data connection" state. I personally turned it off since I like to take control of the data myself and the notification bar control buttons do a great job at that already. :)
Speaking of the notification bar...has anyone encountered a situation where the notification bar seems to freeze up on screen after you pull it down? Can't tap on any of the notices, and if you hit the home button, it seems to clear off but takes a bit of time (15-30 seconds). Will keep happening each time until you reboot, where it works for a while then starts with the same problem.
cpoole89
