ICS Bug Reports
I use my phone almost all day I don't have any problems. I notice that with ics it uses more ram.
Sent from my LG-LS840 using Tapatalk 2
I've noticed that, but it seems to manage it well. I don't see lag from the lack of resources.
Sent from my ICS-Flavored LG Viper using Tapatalk 2
The only thing I hate about the stock launcher is when you download new apps it does not put them in alphabetical order in the app drawer and there is no setting to rearrange the icons by size or name or download date. Other then that one issue I have not one problem with force closes or freezes. I did root right after update and did a factory reset and it kept the root after the factory reset. You just have to reinstall su after the reset.
While in app drawer
Hit menu --> reset
sent from my LG Viper using my thumb and Swype.
So just to confirm my root method still works? Really!!?
Sent from my SPH-L710 using Tapatalk 2
You do realize we all know Shabbypenguin released this method...Just letting you know, i appreciate you bumping it/paying it forward, but i didnt see any recognition for shabby..
Memory management is completely different in ICS, more background cached apps, so yes it will seem like you have less free ram, but in reality, having some apps cached ( it needs a lil tweaking ), increases performance overall.
- - - Updated - - -
I'm not getting a notification blink from my led, I'm rooted on ics. Obviously. Lol can I just do a factory reset n hope for the best? I did the manual install.
I just started a thread about this. I believe i may have found the problem
Speaking of the notification bar...has anyone encountered a situation where the notification bar seems to freeze up on screen after you pull it down? Can't tap on any of the notices, and if you hit the home button, it seems to clear off but takes a bit of time (15-30 seconds). Will keep happening each time until you reboot, where it works for a while then starts with the same problem.
THIS. Seems to be triggered whenever a new notification icon pops up.
Also, if left untouched, the entire notification bar disappears and seems to reset itself, but the pull down issue still persists.
My mobile data connection is disabled and I haven't been able to enable it since the upgrade. It's really frustrating when these things happen after upgrades. *Sigh* Does anyone know how to fix this?
Go to settings, activate device.
Hey my viper did the same said fast reboot twice and long time no see how did u flash it or reset it....?? I would also like to flash back to gingerbread could you fill me in plz.
can any explain easy why how to install CWM sprint lgls840 4g after rooting with firmware.......ls840zvi...thankx
cpoole89
