Ics official release today.
here is a recovery log I pulled with a blank update.zip on my sdcard
C:\Users\Michael>adb shell
$ su
su
# cat /cache/recovery/last_log
Starting recovery on Thu Jan 1 22:36:50 1970
framebuffer: fd 4 (480 x 800)
recovery filesystem table
0 /tmp ramdisk (null) (null)
1 /boot emmc /dev/block/mmcblk0p8 (null)
2 /cache ext4 /dev/block/mmcblk0p28 (null)
3 /data ext4 /dev/block/mmcblk0p29 (null)
4 /misc emmc /dev/block/mmcblk0p25 (null)
5 /recovery emmc /dev/block/mmcblk0p13 (null)
6 /sdcard vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1
7 /system ext4 /dev/block/mmcblk0p27 (null)
Command: "/sbin/recovery"
ro.secure=1
ro.allow.mock.location=0
ro.debuggable=0
persist.service.adb.enable=0
ro.build.id=ZVC.GWK74
ro.build.display.id=ZVC.GWK74
ro.build.version.incremental=1d4e142
ro.build.version.sdk=10
ro.build.version.codename=REL
ro.build.version.release=2.3.7
ro.build.date=Tue Mar 27 11:17:43 KST 2012
ro.build.date.utc=1332814663
ro.build.type=user
ro.build.user=youngsuk.oh
ro.build.host=LGEARND3U8
ro.build.tags=release-keys
ro.product.model=LG-LS840
ro.product.brand=sprint_lge
ro.product.name=cayman_sprint_us
ro.product.device=cayman
ro.product.board=MSM8660_SURF
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=LGE
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=msm8660
ro.build.product=cayman
ro.build.description=cayman_sprint_us-user 2.3.7 ZVC.GWK74 1d4e142 release-keys
ro.build.fingerprint=sprint_lge/cayman_sprint_us/cayman:2.3.7/ZVC.GWK74/1d4e142:
user/release-keys
ro.build.lge.version.release=LS840ZVC
rild.libpath=/system/lib/libril-qc-qmi-1.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV,RUIM
DEVICE_PROVISIONED=1
debug.sf.hw=1
debug.composition.type=gpu
debug.overlayui.enable=1
dalvik.vm.heapsize=48m
dev.pm.dyn_samplingrate=1
persist.cne.UseCne=false
persist.cne.bat.range.low.med=30
persist.cne.bat.range.med.high=60
persist.cne.loc.policy.op=/system/etc/OperatorPolicy.xml
persist.cne.loc.policy.user=/system/etc/UserPolicy.xml
persist.cne.bwbased.rat.sel=false
persist.cne.snsr.based.rat.mgt=false
persist.cne.bat.based.rat.mgt=false
persist.cne.rat.acq.time.out=30000
persist.cne.rat.acq.retry.tout=0
ro.hdmi.enable=false
lpa.decode=false
lpa.use-stagefright=true
media.stagefright.enable-player=true
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
media.stagefright.enable-fma2dp=false
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
media.nexplayer.disable-player=false
media.nexplayer.disable-scan=false
media.nexplayer.enable-lpa=false
ro.use_data_netmgrd=true
persist.data_netmgrd_mtu=1422
persist.data_netmgrd_not_4g_mtu=1472
ro.emmc.sdcard.partition=17
persist.timed.enable=true
persist.audio.fluence.mode=endfire
persist.audio.vr.enable=false
ro.opengles.version=131072
ro.lge.touchkey=BACK|HOME|MENU
ro.bluetooth.remote.autoconnect=true
ro.bluetooth.request.master=true
debug.bt.discoverable_time=0
ro.qualcomm.cabl=1
ro.sf.lcd_density=240
ro.cdma.home.operator.alpha=Sprint
ro.cdma.home.operator.numeric=310120
persist.service.usb.enable=unset
persist.sys.email.crypt=0
persist.sys.email.crypt_ext=0
persist.sys.email.crypt_int=0
persist.sys.sdcard.enable=1
persist.telephony.oosisdc=false
ro.com.google.clientidbase=android-lge
ro.com.google.clientidbase.ms=android-sprint-us
ro.com.google.clientidbase.am=android-sprint-us
ro.com.google.clientidbase.gmm=android-lge
ro.com.google.clientidbase.yt=android-sprint-us
ro.camera.sound.forced=1
ro.config.ringtone=Anticipation.ogg
ro.config.notification_sound=Acoustic_Guitar.ogg
ro.config.alarm_alert=Alarm_1.ogg
ro.com.android.dataroaming=true
ro.vendor.extension_library=/system/lib/libqc-opt.so
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=2.3_r9
net.bt.name=Android
net.change=net.bt.name
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.factorytest=0
ro.serialno=7045f8
ro.bootmode=unknown
ro.baseband=svlte2a
ro.carrier=unknown
ro.bootloader=unknown
ro.hardware=qcom
ro.revision=0
ro.emmc=1
ro.lge.hw.revision=Rev.1.0
ro.lge.boot.cause=keypad
ro.lge.rst.flag=rst_recovery
ro.lge.usbcable.info=normal
ro.lge.usb.type=normal
init.svc.recovery=running
init.svc.adbd=stopped
Check sdcard for GOTA update : /sdcard/update.zip
Finding update package in sdcard...
I:Update location: /sdcard/update.zip
I:Update file path: /sdcard/update.zip
Found /sdcard/update.zip...
apply /sdcard/update.zip via menu to proceed installation.
manual select menu
Okay, I took the easier method of getting the recovery this time, (as my buildbox is building ics) so here you go.
Edit: Depreciated.
it looks good but there is no enter button volume up and down work, home and menu on the soft keys work up and down as well, back, search and power do nothing
Is it usuable though is the real question. And do me a favor and click vol up - vol down - vol up - vol down. That should enable the back button, which allows selecting on items
The new one has a fixed background, but still no "enter" button
Sent from my LG Viper 4g LTE using Tapatalk 2
Is it just me or has CyanogenMod made a lot of changes to their repo? It shouldn't take this long to sync? :confused:
Are you syncing the whole repo as in everything or just a branch of it?
Sent from my LG-LS840 using Tapatalk 2
Cmon yall make your own thread to keep it a uncluttered mess to find something
Not yet working on a way too reveal the link. I am not 100 percent sure if i can do it. but i am going too try my best
Ashok Dharshan
