Ics push
Has anyone confirmed if this kills root? Does ota rootkeeper work? Our should I unroot before the update?
Sent from my DROID RAZR using Android Central Forums
The Moto website says limited push now. Full rollout soon.
Use Voodoo.
First, UNFREEZE ANYTHING you have frozen. Unfreeze it all. Note, after the update, Titanium will not show what was "unfrozen", so make a list.
Absolutely use Voodoo to unroot before the update, and use Vodoo to restore root after the update. Also, if you have a root firewall installed, disable it before the update.
That is all.
Reactions: anon(18763)
I think you guys will be happy. Im not seeing any bugs, battery drain seems fine.
Sent from my DROID RAZR using Tapatalk 2
What are soakers? All I know is that I still have not received my ICS push update.
Let me get this straight if I understand this right motorola sent ICS push update to those who signed up for the soak test and in a few days if everything goes well with the soak test verizon will send out the update via system update? So if that's right keep checking your system update.
Sort of, but some random non soak testers have reported getting the update too. In other words, soak testers were given guaranteed access while the rest of you hope it comes to you next. :p
try a bite of this guys
I hate to stress that hitting that button wont do a Damned thing for you. It is going to be pushed out. You will get a full screen notification with an option to I stall now or later. If you choose later... You can then hit the check update and install.
I just received the file Blur_Verizon.6.12.181.XT912.Verizon.en.US.zip at 6:44am EST and can't open it using Astro. I powered down hoping it would kick in and no luck. Any suggestions?
Oh, I'm just outside of Boston.
Thanks!
Thanks!
Nothing in NY Long Island East Nassau County yet.
I'm getting impatient. :*( ....no update yet. I'm in Michigan.
heritagevines37
