Idiots Guide to Rooting and Custom ROMs, Optimus S Edition
Simon,
Yes I am literally copy and pasting the step by step instructions into the adb shell. And again, the time I get the error is when I have already copied the custom recovery files to the root of the sd card and then start to copy and paste the commands in from there.
Please, give us a screen shot, like psaurus81 did, or copy the command prompt text.
Hopefully I can find time to tackle this tomorrow. I'm new to the whole Android thing, but rooted my Palm Pre. The only question I have is about the backups. Do they save your settings? Like notification, screen, etc? Or is it just contacts and game data? I've got my fingers crossed that I won't be posting in here about the $ or # issue.
Great guide btw.
Ended up rooting last night after the family went to sleep. Couple of issues with your guide.
Section 1
1.a) Java Runtime Environment
When I went to install the Android SDK it said the JRE is not a valid platform for the application. I had to download the JDK from here Link in order for it to work.
Section 3
1) You need two files, flash_image.zip and recovery-RA-GNM-thunderc-s-1.1.0.img.zip, both of which can be found towards the bottom of the original thread. Copy them to the root of your SD card.
These need to be EXTRACTED to the root of the SD card not just copied. Knowing this in the beginning would have saved me a lot of time and headaches.
i am so absolutely positive that i am in the right folder because i only have ONE folder and it is called tools NOT platform-tools. and i am still getting the "adb is not reconginized as an internal or external command, operable program or batch file." error. what the crap is wrong?
Do you see the "adb.exe" file in that folder? If not do a search and find the folder where it is at, and then "cd" to there and execute from there.
well, I've gotten to the command prompt part. i copy and paste [adb push rageagainstthecage-arm5.bin /data/local/tmp/rageagainstthecage] and all I get is error: device not found.
yeah, I need help :/ I reinstalled the drivers also, so Idk whats wrong..
Im having the same problem anyone have a solution???
i need help on the command promt part when entering the first step which is putting the tools folder.
when i enter all i get is
'android\platform-tools' is not recognized as an internal or external command,
What is the command string you are entering when it returns the error? My guess is you are pointing it to the wrong directory. Did you open it up in Windows Explorer to see what folders you have? I would try android\android-sdk-windows\platform-tools just to make sure.
Are you sure it isn't android\android-sdk-windows\platform-tools? That is what my default directory was, so unless you changed it it should be the same.
im pointing it to the right directory its just not seeing the device... do i need to download drivers for the phone onto my computer with the lg thingy??? if so how? im having problem with the lg updater.
Are you talking about the LG Updater box in the middle of your screen with the red progress bar? If so it took me probably six tries to get past that screen. If it stalls out for more than a few minutes, you'll need to ctrl+alt+del and click on the processes tab and kill the LG one and try again. You definitely need to finish that step before trying to get into adb shell
now i type in "adb push rageagainstthecage-arm5.bin /data/local/tmp/rageagainstthecage" and it says no such file directory???
i take it this will take a wile... this being a form and every thing... if you have an answer can you please pm me... i really want thunder rom on my phone
i dont understand this part?
how do i get to sdk
2)Plug in the phone like we did in Section 1, and open up the ADB shell (like we did before- enter the cmd, navigate to where your SDK is installed, and type adb shell).
i just wanna know why cmd says it cant find the file, should i just skip the very first step?
alright im trying to flash my phone and i get this a dolor sing instead of a # sing... wtf
Blakes7
