In a bit of a pickle.
Me to thanks for the help guys it was looking hopeless for a second. But while I'm here does anyone know why It is that I can't get busybox to install
Are you trying to install it over 3g or wifi? Mine always fails on 3g but the download works great on wifi
Sent from my LG-LS840 using Tapatalk 2
Through busybox installer it says the install was a success but when trying to run a script busybox cant be found
okay so i the recovery that just got ported annnddd i got a little ahead of myself. i wiped system and data and all of those fun things because i had to be curios and flash the update.zip that was made for ics and was not ready. now when i try to use the unbrick method that n0ve posted a while back lg phone tools says there was a fatal error...uh oh. so my question is does anyone know where a full update.zip is? I have come to the conclusion that flashing that is my last hope. If anybody can give me any advice here i would be greatly appreciative if you need more details just let me know.
Hold on, you wiped /system and /data? WHY? The zip might actually work, but it's an upgrade zip not a full install! You need to be on ZVD and flash! TRY, TRY, TRY. :D
Anyway you could post the ics update zip that got made I can't seem to find it right now.
You don't want to try to install it, it is not working. Does not boot correctly, boots to recovery each time
If it installs that's all that matters. Post it and let us work with it
Sent from my LG-LS840 using Android Central Forums
Prince08900
