Incognito mode?
Next time use Android app "The Red Dorm" (www.thereddorm.com)
No adverts, no links, free to use, everything is in the app, without web navigation. Best solution.
I just requested my beta key to try it.
Cheers!
I accidentally turned off a locked tablet whilst on an incognito tab will it still be there once it's turned on??
Okay but what about how to find out if your significant other has been usin it? Can you do that? If so how??
If you open the Chrome browser and then open a new incognito tab click on the search bar at the top and then above your keyboard you will see one or two words that pop up and then next to that is a arrow that you can click and it'll have a drop down box with all the stuff that they searched. That's not deleted unless you actually hold down the word and remove it from learned words.
tota
