- Jan 8, 2011
- 13,762
- 9,954
- 113
I wish I could.Cheers Laura! Could you do the same thing with my last tax demand?
Yea, shows same. But what I don't know is what it showed previously, so don't know if changed or not or if any issue. All my apps updated last night, so so far so good. But Netflix wasn't one of those. Guess time will tell and confident that if it is an issue Tmo will correct. Thanks for the heads up though.You can launch it, but you might not be able to update it. Go into your play store settings and look at the bottom of this screen, does it say certified or no ?
Updated to 9.0.2 and now Google Pay is broken. A few people on the OnePlus Community Forum are seeing the same thing.
It broke Google play certification
Fix from the OnePlus forum;
Hold down on the Play Store icon for 2 seconds.
Click App info.
Click Storage.
Click clear Storage.
Worked for me.
He's not lying...Fix from the OnePlus forum;
Click App info.
Click Storage.
Worked for me.
Interesting, the certification no longer shows in my play store settings. I've scrolled all the way to the bottom My Play Settings looked like everyone else's earlier.
Also noticed looks like new build. I didn't do the clear storage.
So perhaps it's not clearing the storage that's resolved the problem but Google made a change? //uploads.tapatalk-cdn.com/20190109/29cc8ef42f66d7ab74a3b23d4fa8be86.jpg
Take the screenshot first, then open the image in the Snapseed app, and use tools and healing to remove anything unwanted.I'm trying to delete it and it won't smh
You're welcome.Thank u so much, greatly appreciated
Did that and settings still doesn't show a line that shows certification status. So looks like newer build of play store that i have removed showing that in the settings.Google/TMobile fixed it on their end. Clearing the cache just allows the fix to show up.. https://www.tmonews.com/2019/01/t-mobile-oneplus-6t-update-breaking-play-protect-certification/
I got my update. Can someone confirm or deny if this update is equivalent to the new OOS version that released with the fixes or is it just the international capability fix like their doc shows?
[/URL]
This is exactly the same firmware as the previous release back in early December 2018 and roughly equates to the global OxygenOS 9.0.5 release, see, here. Even down to the same old November Android Security patch and the same camera version v2.9.43. The only change is, as T-Mobile (USA) state... "Enables support for additional domestic roaming partners"
