[INIT.D SCRIPT] Tweaked Loopy Smoothness
I'm confused. Can I copy to System/etc/Init.d and remove the .bin file extension?
Also, can you link me to? I wanna see screenies. :)
It shows up as a .bin file for you? Weird.
Sent from my LG-E739 using Tapatalk 2
Showed as bin for me .... but it worked so I don't know I'm confuzzled
Sent from my LG-LS670 using Tapatalk 2
Also showed as a .bin for me as well. I'm using Root Explorer, maybe that's it?
No I think it just uploaded that way on box. The file extension isn't gonna make a difference, but remove it anyway
I removed the .bin and installed to Etc/Init.d
Don't know if its working right, but I also ran it with SManager
Yes. I don't know if I put it in the right place xD. Then again I set it like
x x x x x x
x and not. x x x
x x x x
I may add one specific to ADWLauncherEX later, maybe a couple of other ones too. I just wanna try out some launchers with the tweak first.
Sent from my LGL55C using Tapatalk 2
Hey Leo I can try making this a flash able zip if you would like
mostafamu
