Inspire 4G Screenshots: Share Them Here!
My first wallpaper (picture I took a while back) and clock widget (using "Make Your Clock"). Still getting the hang of things at this point, so I'm sure it will change again soon. Also, I have not rooted the phone.
What is the widget below your clock with the weather, memory and battery level displayed?
I basically created that widget using the "Make Your Clock" program. If you get the paid/pro version instead of the free version, you can add in various options for weather, battery (including battery temperature), and memory.
Here are my most recent:
I was finally able to get a screen shot of my home screen
I did not have to root anything. I installed the android sdk and also htc sync (for the usb drivers)
I had to start the sdk and then run C:\Program Files\Android\android-sdk-windows\tools\ddms.bat
which weather app is that?
That's one of the HTC weather widgets that comes with HTC Sense.
i am new to android/htc sense, so when i look on my inspire i see htc hub and htc likes. but i do not see a weather widget. please help me find it.
On one of your screens, where you have empty space, touch and hold on the empty area. A "Personalize" menu will come up, press "Widget", then scroll down to Weather (HTC), then you will have 3 different size widgets to choose from. The one that's in the screenshot is the 3rd one.
thank you so much...i need a tutor for android/sense
My Inspire 4G
Here is a screenshot of my Inspire 4G: non-rooted and using Go Launcher EX as my theme.
smith-jhone
