Installation with error code of '504', please help!
Xia Gu Cao
9
Dear All,
My N7 II was working properly after upgrading to Lollipop 5.0.2 till few days ago while I tried to update some apps. At the beginning, it just couldn't update or install any apps with error code of '504'. I did as suggested (suggestion from google site) that, cleared the cache for Google play and Google play services, and also remove gmail account and re-login it, yet nothing helps. As a result, I did factory reset, the situation still remains. Sometimes it just mentioned that, Play Store isn't installed.
Anyone has any ideas what is going on? Is that anything related to virus infection?
Any inputs will be very much appreciated.
Many thanks.
B. Diddy,
Thank you so much for your attention. But the aforesaid suggestion is not working for this issue as well. Thus, it ended up with re-flashing stock (5.0.2 lollipop), and seems working properly so far. I will follow up this thread if any abnormal issues occur.
Thank you again.
shy_panther
