Question iPhone 14 Pro Max vs honor magic v3
Adel516
Good morning all
IOS vs Android question
I have been using the IPhone happily for the past 4 years
I wanted to ask the experts following
I’m thinking to buy the new Honor Magic V3
1- will I be able to transfer ALL my data and app history over from IPhone to honor
2- honor belongs to the same company as Huawei I think - what’s the update on Google apps ?
3- is it a bad idea and I’ll suffer ?? 😂
Welcome to Android Central forums.
I see the Honor v3 just released in September making it a fairly new model device. I would venture a guess to say that you shouldn't have any issues changing from Apple to Android. I don't know that app history transfers, history would imply that you would find the same apps on both platforms, and that may not be the case for all apps. You will likely find similar or equivalent apps here on Android but I would imagine only the big ones would be the same. Facebook, Insta, Linkedin, and even in that you should expect some differences as I've heard that many developers curate their apps for Apple differently than for Android where they have to account for different specs from manufacturer and device to manufacturer and device. As for number 2, I can't find a single list that mentions the Honor Magic V3 being on the banned list. Even when it happened there were several Huawei manufactured devices that were excluded. If memory serves it was all about how they were labeled and who distributed them and mostly affected models sold direct from Huawei to consumers, again this is if memory servers me correctly. And 3 is up to you. I've seen a lot of YouTube reviewers who have said both and gone both ways. Said that leaving Apple was easy and that they don't miss it. They may miss a feature or two but overall are happier with Android and vice versa, and here just in the AC threads alone, I've seen people say they could never give up iMessages, or the way Apple's version of Facebook lets you like or reply to messages. It will also matter how deep you are into their ecosystem. Do you have Airpods, Macs, and iPads, things like that? It may be harder to switch.
Anyway we can request that your thread be moved to the Honor threads. @Laura Knotek @B. Diddy @mustang7757. I see one of the last posts over there has 4k views and is fairly recent. Other threads are from 2023 so it isn't super busy over there but Honor folks have the device and would be better equipped to say what the move was like for them and how happy they are.
Magic forum
All of the Honor forums
XDA has a forum for this device that appears to be a little more active at the moment with 4 threads being posted since August. You can find that here.
There are a couple of threads on Reddit but that's about all I see for places known to allow posts and expect answers.
Best wishes and hope you enjoy your new device.
Magic forum
We wait and see probably better off here for the moment
Welcome to Android Central! One major issue to keep in mind is that any app you had to purchase in the App Store will have to be re-purchased in the Google Play Store -- app purchases are not cross-platform.
The ability to carry over app data will also depend on if the app saves or syncs its data to a cloud server. If it does, then that should be no problem. However, if the data is only locally saved, then it will be difficult if not impossible to move that data from an iPhone to an Android device. And even if the app syncs to the cloud, that may be problematic if the app on the iPhone syncs by using the user's Apple ID (which is typically not available on apps installed from the Play Store).
Reactions: Madd62 and VidJunky
BekaH
