BlurryEyed
- Jul 2, 2012
- 294
- 0
- 0
Re: MXPE 16GB owners - is it enough?
Thank you. My plan is to do a factory reset, convert the SD card to adoptable storage, then proceed with configuring the phone.
They would stay, so to speak, because the only way to move apps to the SD card is to format it as adaptable storage and the phone would consider (and show and report) the SD card as internal storage. So, basically, it would show the internal storage as 16GB plus whaytever size card you have so something like 32GB if you had a 16GB card in there. If you do not go the adaptable storage route and just use it like any other SD card you can't move apps onto it, just media.
