Is it possible to physically install a monitoring chip on my samsung galaxy mini s3lte if so where?
A
AC Question
Apps I didn't download keep popping up, some refuse to shut off or I don't have any options. + other weird stuff. I tried a factory reset no luck.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,620
4,762
113
Welcome to Android Central! I really doubt anyone installed a chip in your phone. When you did a factory reset, did it automatically reinstall all of your apps? If so, one of those apps might be carrying adware or even malware. You can tell if it's a 3rd party app by booting into Safe Mode: How to boot the Galaxy S3 into Safe mode? | Support | SAMSUNG Levant
If the behavior goes away in Safe Mode, then do the following:
1. Go to Settings>Backup & Reset, and uncheck "Automatically Restore."
2. Do another factory reset.
3. When you're done with the Setup Wizard, go immediately to Google Play Store, and stop any apps that might be automatically installing.
Now see if that behavior persists. If it's gone, you can start reinstalling apps one by one, checking between installations to see if that behavior returns. If it does, you know it was the last app you installed that was carrying the bad stuff.
justinedwards
