Is Jellybean on your Sprint Galaxy S3 yet?
I did. 60656 here.
The old "Google Service Framework" trick worked again. Had to do it few times but finally received the update. Surprisingly hotmail in the stock email application works how it should now.
"All applications-google services framework-clear data, then back to system update-update samsung software."
This worked perfect. It took me roughly 4 tries and it worked. Now running 4.1!!!
Force stopped & cleared data to Google Services Framework. Update forced OTA after about 6 tries. Love the update. Google Now is a nice addition but definitely needs to be tweaked. I know it will come with time though. Step in the right direction! :)
Is there a certain order that you must do? I've been doing it with no luck unfortunately. Oh well...guess I'll just have to wait in agony :/
The Google Framework trick worked on my second try. Downloading now.
Did the same thing and it finally worked!! Loving Jelly bean so far!! Will test Google Now later. For now I can honestly say that everything in this phone became much faster. From transitions to opening apps. Smooth as butter. Although there are a couple of hiccups here and there, but I think it's on my end as I've downloaded some questionable apps that might it slow it down. Overall, I am loving it soo far! It's also funny trying to see everything is super fast when you put the Transition Animation Animation Scale at .5x.
Good luck who hasn't gotte it yet!
Cleared the data in Google Services Framework app, and after a reboot I got the OTA update.
Sent from my Sprint Galaxy S III using Tapatalk 2.
I have it downloaded, how do I place it on the sd card?
Hook your phone up to your computer as a media device (check your notification shade, it will give the option to use it as a camera or media device), then just copy and paste the file from your computer to your sd card and follow Skunkapes directions for your particular situation. If you're not rooted and if you're on stock rom, go with the Post 2 method.
stoffe949
