IS my phone dead inside? or is the screen in need of repairing? HELP
  • Start date Start date
A
Android Central Question
I purchased a xiaomi mi mix 3 about 4 ish months ago. on the first month i had accidentally dropped it, it then had minor cracks on the bottom right corner on the screen. However it worked fine like it did before. completely fine.
then a couple days ago. i hadnt dropped it or nothing like that. and the screen went pitch black with some dark green on the right side of the screen. now its just plain pitch black. with no sounds. nothing on the screen.
just vibrates when i press the power button. when i connect it to a laptop or computer it does not recognize the device. but knows that i am trying to connect a device to the pc.
i do not no what do to. just for the screen itself is 100GBP. then on top of that i need to pay 20GBP for someone to install it. thats all together 120GBP. but i do not want to do all of that to find out later afterwards that it still does not work and isnt the screen that was broken. so i need help what are your thoughts?
i cant tell when its on or off as the screen is blank black. it just vibrates whenever i press the power button. i have tried many techniques like doing the hard reset button ect. there are no sounds, its quiet. but vibrates.
thanks.
Welcome to Android Central! Those drops must've added up. You'll need to bring it to a repair shop. In the future, get a good protective case, since you seem to be prone to dropping your phones.
kiki2025
