Is the native battery of Note 3 replaceable?
Thomas_George
137
18
The native battery of my Samsung Note 3 becomes poor in performance recently.
So I wonder if I can replace the battery. And if I can, which brand will be better for our Note 3?
Thank you in advance.
Yes it is replaceable. Here are several. I don't know if those Samsung ones are really Samsung or not. Samsung doesn't list batteries for the Note 3 on their shop.
Remember if you use NFC, you have to make sure the battery is NFC because the coil was built into the battery with the Note 3. Those are a little more expensive and there are some reliable brands listed on the first page alone.
https://www.amazon.com/gp/aw/s/ref=...ag=hawk-future-20&ascsubtag=UUacUvbUpU5318298
I just purchased a OEM battery for my Note 3 on E bay.
It is identical to the original.
So far no problems at all.
slackingfred
