Is there a way to activate a notification light on my s10 plus.
  • Start date Start date
A
Android Central Question
Finally upgraded from my old s5. It had a feature I really liked, it had light in the upper left corner that showed red when it was charging and blue when I got a notification without screen having to be turned on. Does my new s10 plus have this function, if not is there an app I can get that does?
Hi, if you can make a account here,me or other members be happy to assist you.
There are apps you can download in play store
The notification LED was removed to make room for the "bezel-less" display.
However, there are some apps that supposedly light a ring around that big group of dead pixels in the upper right corner of the screen.
I mean...
...around the camera hole.
nakimefan
