Is there a way to put the mobile data toggle into the notification bar?
this is old yes...but still gay...tmo does not have the lte toggle off? MIne don'e either! lame! i appreicate the widget and am looking into that as we I type (like the install from computer play options) but I had a new thought....Does turning data on and off frequently affect battery life as if having a low signal? It seems to me it would becaue it would be searching every timeI turn it back on. Which I can do several times. Its like pick the phone up turn it on...et it down turn it off...IDK
Merry christmas!
The sprint note 2 didn't have it either. My tmobile note 2 doesn't have it either. Only way I had it on my note 2 is by installing a rom that put it in there.
Only thing I can find is go to widgets, choose the "settings" widget and then choose "data". It will put a data "button"on your homescreen that will open the data page and you can uncheck the allow data.
Thanks! I found the answer...SQL light editor from play store...root required i believe...then add Mobile Data to an area whoms name I do not recall right now. Super simple and thanks for the reply! ps had widgitizoid and that sucked!
Update the Tmobile account info app. Then after updating there is a little box to check whether you want it on or not. Had this problem with taking it off of my notification bar. Horn this helps
i have s6 edge and from the notification bar mobile data on off witget has been lost. i have tried to edit the notificatoon bar but i could not find the witget.
Try going to Settings then notification panel
Sent from my ASUS Transformer Pad TF700T using Tapatalk
VascoPJ1377
