Is there a way to set a "bedtime" mode on the Droid X?
timeriffic is a great option as well
Timeriffic lets you automatically turn off WiFi, Bluetooth, GPS, and turn on Airplane mode at your preset time. Then each morning, it can turn it all back on for you. It's free but showing its age a bit not allowing GPS triggers like the others do. But it is simple, saves your marriage and your battery.
Here is the link to Timeriffic:
Timeriffic - Android app on AppBrain
Use AppBrain to download apps because Android Market is too stupid to let you search for apps from your PC.
Here's the link:
AppBrain - the best Android apps and games on the Android market
AppBrain will also let you install directly from your PC using this app:
Fast Web Installer - Android app on AppBrain
Do any of these also turn off the flashing lights at night, same as BBs Bedside Mode? I have the sound very low for alerts and they aren't a problem, but the flashing red light makes us feel like the Fire Department is parked outside.
I bought PROFILES in the marketplace, then found EAR. I like EAR better. Just do a search. Basically works just like the Blackberry.
How do you disable all sound but still enable your alarm to go off. I dont want to get calls or notifications when im sleeping so i turn my volume waaay down but my alarm hasnt gone off for the 2nd day so far.
If you hold the VOLUME DOWN button until the ringer volume goes down, it will then go to Vibrate. keep holding and it will then go to "Ringer Off". In that mode, only alarms and media you play will have sound.
byronsss
