Is TMobile's $30 4G plan gone?
When I click on the activate button it brings me to another page where I have to enter the activation code, sim card number, and IMEI. What is the activation code?
I've had the plan for a while and it sounds like the activation process has changed. I suggest calling T-Mobile customer service and checking with them. Good luck.
Sent from my Galaxy Note II
It says I can find the code on the activation card that comes in my prepaid phone box from tmobile. I want to buy the nexus 5 from the play store, do you think that has the activation card they are talking about, or can I not buy it from the play store?
You order the simcard from T-mobile; it has the activation code. Occasionally the simcards are available for free otherwise they are $10. You want to select "Bring your own device" on T-mobile.com.
You order your Sim card, whatever size your phone uses. When you get it, it will have an activation code with the kit. Then you go online and activate.
Sent from my Nexus 4 using Tapatalk 4 running Android 4.4
arcworldwide
