Issue with auto-bright feature
dmateo
412
I'm currently experiencing an issue with the auto dim/brightness feature where it isn't automatically allowing the screen to adjust itself based on lighting. This just started happening after I swapped out batteries. Anyone else experiencing this?
Posted via the Android Central App on my Note Edge
Surprisingly it fixed itself after I pulled the battery and reset. Thanks for the tip I will download the app you're recommending as well.
niv141
