issues with Launcher Pro
gregba
181
4
does anyone that uses LP as their launcher sometimes get severe delays with it?
I do fairly often, and have uninstalled and re-installed it which didnt help.
There are also times that when I come out of an app, the screens are blank for maybe 6-7 seconds before my icons/widgets appear. Are there any solutions to this?
Thanks!
Pretty sure it is a known issue. I have it and so do others. I just swipe left or right and everything reappears
Charged up post!
I'm not sure if you should anticipate any updates. The update for that was May 17,2011.
Sent from one of the following: Galaxy Nexus, Bionic or Xoom using Tapatalk.
In a post on their forum they stated an update was on the way soon. I think the lack of updates are an "don't fix what isn't broke" kinda thing
Charged up post!
Charged up post!
that doesnt always solve the issue- very frustrating
I hope it is fixed soon, otherwise i might switch to go launcher or something else
There has been no development on LP for quite a while now. I don't get the impression that there is going to be any either. The site's forums are static.
Reactions: pauldroidr2d2
bonbon
