Issues with Live Message
So folks.....Here is the issue with Live Messages failing to send on AT&T.
AT&T has what they call "Advanced Messaging" which increases the
send/receive limits from 1MB to 10MB but unfortunately because AT&T plays dirty they restrict factory unlocked US devices from being able to use this feature. You must use a locked AT&T carrier version for Live Messages to send properly regardless of whether you use the default messaging app or Textra. In the carrier version you have the option to enable "Advanced Messaging".
iMessage 10
Live Message 0
Sounds like an AT&T thing to do. They don't allow a lot of stuff to work with phones that aren't theirs.
Textra never worked for me, started using stock, now having issues with that. I started using Google messenger, seems to work great
There is a new update for live message to reduce file size. Just FYI. Galaxy app store. About 12 to 14 other updates for other apps also FYI. May fix send issues.
wobblefix
