Issues with Nexus 7, 3G model, mobile data won't stay turned off...
signalexc
Just got my Nexus 7 w/ 3G and couldn't be happier, but having a weird issue, and wanted to see if anyone else was experiencing the same thing.
Once I activated my 3G service (AT&T), I went into settings>data usage and disabled mobile data. I did this because I have wi-fi at home and at work (I work at a University) and don't need it most of the time. However, once I arrived at work, I noticed that my mobile data had turned back on. It happens when I go between different wi-fi networks; I will manually disable mobile data, only to have it turn on again once my nexus 7 connects with a different wi-fi network. I am worried that if I forget to disable the mobile data every time I am in between networks, that once I am out of range of wi-fi, my mobile data will activate and begin eating into my monthly allotment.
Has anyone else with a 3G model experienced this? I am currently running Jellybean 4.2 (most current update) on a Nexus 7 w/ 3G - only had it a couple of days. If anyone has any advice, I'm open.
Thanks.
Yeah, I run into the same issue with my Nexus 7 3G too. Just like certain cell phones, in order to disable mobile data, you can put the device in airplane mode then turn on WiFi.
there should be an easier alternative than airplane mode (IE a way to toggle the radios on and off)
That doesn't work either. It keeps coming back on.
Let me try to help clear some things up with mobile data on the Nexus 7.
Unless you're in Airplane mode, if there's a Micro SIM in the Nexus 7, it seems the cellular data bars icon is always on.
When you have Mobile Data enabled, you should see a small "H" (HSPA+?) next to the signal bars.
When you uncheck the Mobile Data enabled box, the "H" goes away, but the signal bars still show, but you can't connect to the internet.
Thanks for the clarification Danny. (Why is there no option to use the "thank you" button on Tapatalk? Argh.)
Sent from my YP-GI1 using Tapatalk 2
Got mine Google Nexus last night. I guess the SIM came pre-paid, but I have already spent a good half of data without even knowing it... So sad. Trying the Airplane mode now. I hope it works.
The most weird part is that I didn't have to type in password for the office wi-fi - it knew it. I don't know how. I really don't know. I do have Samsung Galaxy 10.1 - could it be because of it? Magic...
Google backups your settings online (including wifi). I auto connected to my gfs wifi when I went to her place. No entry required
Sent from my EVO using Tapatalk 2
And it still turns itself back on, seemingly randomly. I have tried more than a few widgets for toggling mobile data and airplane mode and have yet to find anything that works consistently.
Me too
Sent from my EVO LTE via Tapatalk
Any updates on this? I'm usually pretty good at finding answers but there's nothing on this... 3G starts on its own. Only workaround seems to be to turn off WiFi then mobile data (so it won't roll over, I guess).
$30 is too much to spend on something I can generally do for free (tether) and while $15 for 250MB is ridiculous (and makes me despise cellular companies all the more) I'm only going to need mobile data on rare occasions. Getting bent over because I can't choose those occasions is infuriating!)
I'm on day two with device. See nothing in Google Nexus Help about this issue. This is annoying enough I'll probably send this back and get the WiFi version.
I've had my Nexus 7 3G since laugh with a data plan. I keep it on airplane mode, and have a widget where I turn WiFi on and off. When I need mobile data, I disable airplane mode and have 3G data. Never had problems with cellular data randomly coming back on, so no issues here with airplane mode.
i have a problem with my nxus 7 3g data, i have a wind mobile sim card inside it recognizes it and says connected to wind, but it says data is not connected? the sim card is active and currently has an unlimited data plan what should i do?
- - - Updated - - -
This is what I do , but I didn't do it right away.
Sent from my Nexus 5 using Tapatalk
kiki2025
