Issues with "No Data Connection" even though 4G shows in notifica
Re: Issues with "No Data Connection" even though 4G shows in noti
Will the next update fix this. I cannot update socstatus with 3 or 4 g service. It says no data connection. Only started after last update? Shouldn't have to toggle airplane mode to get phone to do something its already supposed to do. Any idea about update????
Next update will be ICS (Android 4.0) and they pulled it from the soak test due to so many problems. Its gonna be a while before we see an update probably. I go in and out of 4g spots and don't really have problems. Sometimes it might take it a minute but never have to toggle airplane on and then back off.
Sent from my Eclipsed Droid RAZR via Tapatalk II
I have this issue as well - it's very frustrating. It even happens when I'm getting all bars 4g.
I pretty much just keep mine on 3g. Defeats the purpose of having a 4g phone, though.
Is the 4g icon white or blue?
I had the same problem, resolved issue by uninstalling updates to all the google applications, not which one solved the problem. I did this by play store/ my apps, clicking each google app and selecting uninstall which then pops up saying uninstall all updates, click yes, problem solved, will install again one by one to work out which one/s are causing the problem
jipeve
