It takes 6 hours to charge completely in Sony Xperia C5 and phone heats up. So what is my solution?
  • Start date Start date
A
AC Question
It takes 6hours to charge completely in Sony Xperia C5 and phone heats up. So what may be solution
It takes around 6 hours to charge completely in Sony Xperia C5 and phone is getting heated up even with normal use like using camera for some 2-3 mins. And my phone battery is draining up so fastly...
That definitely isn't normal,I'm assuming that you're using the stock charger head and usb, right?. If so, have u tried using different USB cables? About the Heat when using the camera app, is it to a point where it is unbearable?Has the camera app always been like this for you? Could try wiping cache partition..
Rocking the Gunmetalicious M8
