I've got the Moto X, you've got questions ? fire away!
Re: I've got the Moto X, you've got questions � fire away!
I don't believe you can change settings with stock camera, download the Google Camera, that allows you to do so, and is a better camera IMO
Nope, stock camera app doesn't have picture size options but Google Camera app does. If you use stock camera app, there is an app called Reduce Photo Size that is an option that will allow you to send attachments by reducing photo size after a picture is already taken.
Hi all,
So I bought a moto x (em currently using it) and after I came home and used it for like 1 hour, it started heating up (gradually). I looked up the internet and tried Everything!. Deleted all downloaded apps, disabled some useless apps even Factory reset it, but Its STILL getting warmer as I use it. Like it gets hot to hold right after 10-15 mins of light use like surfing the web etc. I also tried airplane mode but like I said it didn't work. So any suggestions guys? :/
BTW it's at&t running 4.4.4
looks like you are not using Wifi and the 3G cellular data is not very good where you are.. whenever my moto x gets hot i usually disable the data toggle.. so all i am using the talk ad text portion of the phone , no data otherwise my phone gets hot and my battery drains super fast..
lefler
