I've got the Samsung Galaxy S III, ASK ME QUESTIONS!
Is there any way to disable camera shutter sound?
Sent from my GT-I9300 using Tapatalk 2
If your phone is rooted, there is a mod on xda gs3 development that disables the camera sound. At this time, that would be the only way.
_______________
Just Flash It !!!
Most phones are made of plastic. Reviews have stated that the S3 feels very solid.
Sent from my SAMSUNG-SGH-I897 using Android Central Forums
Nah it does not feel cheap...feels very well made and professional even if the back is flexible
Sent from my GT-I9300 using Android Central Forums
Is it true that Samsung or Google have disabled moving apps to sd card functionality using third party apps on the S3? None of the apps that could do this on my S2 work on the S3. Any good reason for this restriction?
Yes its been disabled not sure why though... maybe it makes the software run faster as it doesnt have to load off the sd card.
If voice recognition was a family...siri would be the newborn...svoice is just the jealous older brother... its really badly made lol
Quick question that i didnt see anyone else ask. When playing music with google play music can you hold down the volume keys to change the song when the screen is locked/screen is off. My old desire did this but my Electrify does not. Thanks for the great Q&A
Yes it's true. I hope they(Samsung) change it when more people will get this phone and make some sound.
I have a more simple request because I haven't seen this yet. Can I get some screenshots of the default apps? Primarily what the dialer, contacts, calendar, call screen and messaging screens look like? Samsung always has hideous layouts and wondering if I'm going to have to use GoContacts or something on this device. Would be a shame cause I like a lot of the gestures they added.
Can we display preview of text mesg in taskbar
when we get text mesg How to in settings ?
or which app will do that ?
Can you surf the web, and talk on the phone at the same time over 3G?
While you're on Wifi, definitely. Otherwise it depends on the carrier. I believe on AT&T and T-Mobile you can, because they use GSM. On Sprint and Verizon you can't because of their use of CDMA.
The Evo lte on Sprint can do it over 3G, so I hope the S3 can do it too.
Are you sure? I can see it working over LTE, but not over 3G.
Yes on Verizon you also can since it supports svdo like the thunderbolt and rezound
For the most part, you can't do simultaneous surf/talk on 3G on CDMA networks such as Sprint and Verizon use. There's an exception to that, its called SVDO, and is a technology enhancement that carriers can install into their CDMA networks. I believe you'll find very limited coverage of SVDO from Verizon/Sprint however, as they've been focusing on LTE for their network upgrading, not CDMA/SVDO. The EVO LTE does support SVDO however, so its at least possible that the story posted was true, although he may have been using LTE (4G) instead, which is also fully capable of simultaneous voice/data.
FWIW, the S3 does support SVDO, in addition to LTE. So essentially ANY carrier network (GSM, SVDO, LTE) which is capable of simultaneous voice/data will enable the S3 to give you that function.
The call screen looks better than the previous versions
Also i believe the calendar is now called s planner
Contacts and text messaging looks more or less the same as before
How much NOT like stock ics does it look? Ics is so aesthetically perfect I can't see using touch wiz again.
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Reactions: Mercury81
To me this calendar looks way better
Ive never used stock ICS before and i dont think i ever would in future... this touchwiz feels more smoother to me compared to my s2... just basic touches theyve added like the animations when swiping etc... make it easy to use. but i guess if your not getting this phone because your unsure of touchwiz... then its probably best to try it out in the shop before you buy... :cool:
IMO... Stock AOSP is freaking the most boring UI. CM9 with Nova Launcher was my preference on my ns4g and it will most likely be the same on my gs3.
_______________
Just Flash It !!!
Stock ics asop is the shiiiii though hell even stock gb was too I'm not to hip on all the diff skins besides blur
Sent from my Nexus S 4g using Tapatalk 2
I would like to know does the S3 have the horrible weak antenna like the G2? if so I will not be getting this phone. this is a deal breaker for me.
My s2 did have problems when i was calling... very poor quality... ive had a few long calls since buying the s3 and i think the problems have been fixed... sound has been clear
