Jelly Bean 4.2 Camera
Installed the file from the original post, and no dice. Running Vicious Jelly Bean 4.1.
Wiped cache
Used Root Explorer to place file into system/app folder
Changed permissions to RW-R-R
Wiped GalleryGoogle.apk file from that folder (moved to another folder and renamed)
Rebooted
Camera and Gallery were missing from my app drawer--nothing.
I'm too chicken to actually erase that original GalleryGoogle.apk file entirely. Think that's what's causing the issue?
Try the zip file hidden in this thread somewhere. You can rename the apk to bak. It will still be there when/if you need it.
Tapatalk sent from the GneX
I also flash it and I also get an 2nd Camera and Galery. Camera works but when redering it CF at the end. But the image is in the galery but not 360. How can I view them?
I flashed the zip and the new camera app is working fine, except Photosphere.
I can take only one picture in Photosphere, then it FC.
I have a LG P990 with latest CM10 (4.1.2).
Does someone have similar issues?
Takes wonderful pictures of Romney holding an Obama sign lol
using ES file manager rather than root explorer works well for changing the build.prop! FYI, my issues are fixed :)
Yes nearly the same issues. I can use photosphere, after that it is rendering and fc's at 99%. After that the gallery restarts and seems to finish it, but the pictures are only 1.5mb in size and dont have 3d on g+. Tried everything.uninstall with titanium, cleared caches, cleard dalvik, flashed, .... copied manual, ... Everything else working fine.
Galaxy Nexus - CM10 Nightly
btw.. which app du u use to get the app-log?
@Donald Nice - Same issue... Gallery FC at ~99% :/ I've flashed it using CWM and copy files (with 3 libs) manually using RootExplorer. Renamed .odex and old app as well. -- Galaxy Nexus "maguro" with 4.1.2 (JZO54K), yakju
EDIT: logcat:
Code:
W/dalvikvm( 3386): threadid=33: thread exiting with uncaught exception (group=0x41f46300)
E/AndroidRuntime( 3386): FATAL EXCEPTION: AsyncTask #1
E/AndroidRuntime( 3386): java.lang.RuntimeException: An error occured while executing doInBackground()
E/AndroidRuntime( 3386): 	at android.os.AsyncTask$3.done(AsyncTask.java:299)
E/AndroidRuntime( 3386): 	at java.util.concurrent.FutureTask$Sync.innerSetException(FutureTask.java:273)
E/AndroidRuntime( 3386): 	at java.util.concurrent.FutureTask.setException(FutureTask.java:124)
E/AndroidRuntime( 3386): 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:307)
E/AndroidRuntime( 3386): 	at java.util.concurrent.FutureTask.run(FutureTask.java:137)
E/AndroidRuntime( 3386): 	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1076)
E/AndroidRuntime( 3386): 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:569)
E/AndroidRuntime( 3386): 	at java.lang.Thread.run(Thread.java:856)
E/AndroidRuntime( 3386): Caused by: java.lang.NumberFormatException: Invalid double: "20,041854"
E/AndroidRuntime( 3386): 	at java.lang.StringToReal.invalidReal(StringToReal.java:63)
E/AndroidRuntime( 3386): 	at java.lang.StringToReal.parseDouble(StringToReal.java:269)
E/AndroidRuntime( 3386): 	at java.lang.Double.parseDouble(Double.java:295)
E/AndroidRuntime( 3386): 	at java.lang.Double.valueOf(Double.java:332)
E/AndroidRuntime( 3386): 	at com.google.android.apps.lightcycle.util.MetadataUtils.writeExif(MetadataUtils.java:211)
E/AndroidRuntime( 3386): 	at com.google.android.apps.lightcycle.util.MetadataUtils.writeMetadataIntoJpegFile(MetadataUtils.java:137)
E/AndroidRuntime( 3386): 	at com.google.android.apps.lightcycle.panorama.StitchingService$StitchTask.doInBackground(StitchingService.java:444)
E/AndroidRuntime( 3386): 	at com.google.android.apps.lightcycle.panorama.StitchingService$StitchTask.doInBackground(StitchingService.java:345)
E/AndroidRuntime( 3386): 	at android.os.AsyncTask$2.call(AsyncTask.java:287)
E/AndroidRuntime( 3386): 	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:305)
E/AndroidRuntime( 3386): 	... 4 more
D/dalvikvm(  306): GC_CONCURRENT freed 1916K, 18% free 20993K/25543K, paused 14ms+9ms, total 126ms
V/StateManager( 3386): destroy
I/Process ( 3386): Sending signal. PID: 3386 SIG: 9
I/ActivityManager(  306): Process com.google.android.gallery3d (pid 3386) has died.
W/ActivityManager(  306): Scheduling restart of crashed service com.google.android.gallery3d/com.google.android.apps.lightcycle.panorama.StitchingService in 5000ms
So androidpolice have been doing some work:
We patched the Camera to stop checking for compatible phones when starting Photo Sphere - it should work on all devices now.
That means that I had to update my zip.
What should be working now is:
1. Panorama.
2. Photosphere. (requires gyroscope?)
3. Photo editing.
4. and the ordinary photo/video stuff.
5. Should work on ALL phones.
That means what doesn't work is:
1. Sphereview
Dev-Host - 4.2Camera_t02.zip - The Ultimate Free File Hosting / File Sharing Service
So how does one remove the old and replace with this zip?
Sent from my SGH-I747 using Tapatalk 2
AW: Jelly Bean 4.2 Camera
Same here! On galaxy nexus with cm10 Latest build
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Zip should take care of that, if not delete the GalleryGoogle.apk manually then flash the zip again.
The libs are all the same so there should be no problems there.
Any suggestions on gallery FC after I take a picture? Everything seems to work but after I take a picture it hangs, then FC. I restart camera and it says it can't. Someone said to remove the googlegallery.odex but I can't find it. I've asked where its supposed to be and searched as well to no avail. I'm running S3 ATT version with task's latest 4.1.2 build. Anyone have ideas?!?!?
What rom are you on?
Task650 and ktoonsez 4.1.2. Its their latest AOKP build on an ATT s3.
I might be wrong but I belive that AOKP Roms are Deodexed? that means there shouldnt be any .odex files in /system/app. only apks.
Again: I might be wrong.
If Thats where they should be then yes, only apks. But dang, then that means I have no other option to get the new camera to work on my s3. Sheeeeet.
I may have a solution. Let me get back home.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Jackwills2567
