Jelly Bean 4.2 Camera
Wait so have we gotten photo sphere working yet? So many posts don't know where to look haha. If so how?
Guess what works?
Slide this file into system/app. Fix permissions. Reboot.
Enjoy not having to go to G+.
Everything works except the viewer. At least for a few more moments...
Edit: or a few less moments, it would seem. A little bird told me that answer was coming.
I found that PanoramaClient is provided by com.google.android.gms. new version of com.google.android.gms can solve this problem.
I think that there is /data/app/com.google.android.gms-1.apk
Can any one upload this apk from 4.2 device?
Thanks for the tip, 3 little letters helped me out tremendously.
- - - Updated - - -
Look above dog. Viewer is fully operational. Camera/Gallery is fully operational on the Galaxy Nexus.
Do I need another download. I'm on the original .apk from first post
i just noticed i can NOT upload to google maps like some are saying you are able to, could this be a maps update?
This was the fastest thing I've ever followed to go from idea to fully functioning. You sir are a wizard.
Thanks dude
When I try to go to photo sphere I force close. What is my dumbass missing haha?
Thanks guys love your work :))
everything seems to be working except for taking photo with flash..any ideas?
Sgs3 i9300
Thanks dmmark for everything!
But I still have the same problem: everything else works, but photosphere never finishes rendering. Gallery FC at about 99% of rendering. There is one photo in Gallery, but it's not recognized like a "3D" photo.
I cleaned cache, data, removed gallery2.apk, reflashed the zip... but still the same. Any idea please ?
Manually push it all.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Got it now. Is there a way to view with a 3D viewer?
Thanks for all of your hard work on this. I still can't get the photosphere viewer to work. I tap the globe, and nothing happens in gallery.
Did you reboot? Once you tap it it should populate the photo, and then you can slide it around.
Same here, Verizon Galaxy Nexus, Dark ParanoidAndroid 2.52.1 (4.1.2). I pushed all files manually (2 apks and 3 lib files) and set permissions. Rebooted. Absolutely everything else works (flash, video, etc.) the Photosphere rendered without any FCs, but when the globe appears pressing it does nothing.
Ashok Dharshan
