Juice defender not working? UPDATE- Download beta
Mine got an error as well. I force closed it and opened it back up, it seems to be working now and has not disabled itself like the non-beta version.
I heard JD has a similar feature that can enable/disable wifi based on location. Anyone tried it..and does it use GPS or cell towers?
I've posted in a couple of forums already that the app Green Power works far better on the Bolt and its cheaper than Ultimate Juice. There's also a free version. I suggest you guys try it on your bolts.
Does green power allow you to set provision so that certain apps can access the network whenever they need them?
For instance, I need to stream Pandora while the display is off.
anis
