June Images Are Go!
Everything else works fine for me too - just Magisk's ability to load modules. Magic itself is running fine (even if it's a little wonky to install now).
Oh, I didn't "get" it, I downloaded the factory image and flashed it (after making a full backup).
Since the updates are different sizes for 2 and 2 XL is it possible WiFi is a problem only for the 2? I have a Pixel 2 XL and both WiFi and cellular data are working with no problems. And so far I haven't found an app that doesn't work either.
Doesn't make a difference
Definitely experiencing the same slow down being reported in the press with a noticeable delay in screen turn on with fingerprint sensor.
I've got apps crashing when trying to change settings. Gboard reset some preferences on its own. No slow down though. But kind of annoying, and I did a factory reset.
The slowdown is really bad. If you do not use AOD, it takes about 2 seconds to unlock the phone using the fps. If you use AOD, you won't notice a slowdown. Heard it has to do with a flicker some were experiencing using AOD, but it really affects those of us who don't use it.
I ran into a few problems right after the update but a reboot seems to have fixed those. Primarily it was with a few apps that didn't want to act "normal." Unlock with fingerprint seems to be as fast if not faster than before.
Got my OTA update yesterday. Usually I am one of the last people to get the OTA update.
I've turned it on and off with no difference. I've also heard of people with AOD active that experienced lag.
I am sure it is different for others. In my case, if I do not have AOD active, it takes 2 full seconds to unlock, but if I have it active, then it unlocks normally. Not sure if affects just 2XL or both. Hopefully they can get this fixed quickly
I'm sorry you are experiencing that! Let us know if it fixes on its own or if an update does the job for you!
When I say no difference I mean I don't have lag
PabLitoEmiLioEscoB4r
