Keep adaptive brightness setting on max Samsung S24U
pj737
Active member
May 8, 2017
37
8
With the adaptive brightness setting turned on does anyone know how to keep the brightness on the highest setting all the time? I go for walks during the day when the sun is shining and the screen is very readable with adaptive brightness on even when the sun is shining on the phone. However immediately after walking under a tree canopy or any kind of shade (my walking paths are covered in tree canopies that are roughly 50% of the walking path area) the screen dims down so much that I'm unable to read what's on my screen. Only when I reappear out it to direct sunlight is the screen readable again. If I turn the adaptive brightness setting off the screen does not get bright enough when the sun is hitting it. I would like to keep the max brightness setting on all the time instead of it dimming down once I go under a tree canopy. Is this possible or is do I just have to deal with an unreadable screen (in the shade) while doing my outdoor walks?
Just pull your notification panel down and adjust the brightness bar while having adaptive brightness and do this a couple times that way it learns your habits of lighting in different scenarios .
Reactions: Laura Knotek
I tried this but when I walk into shade and try to move the brightness bar to full bright the brightness level doesn't change. I need to turn off adaptive brightness for it to actually increase.
That's my experience also, for certain odd scenarios you have to just turn off adaptive brightness and manually adjust it.
It should go down automatically once you go into shade pretty quickly , if it's still max brightness I would say try in safe mode
It periodically doesn't (go up or down automatically, quickly). I have experienced it several times also. It doesn't surprise me that walking in and out of shade or direct sunlight over and over again is a scenario that adaptive brightness might have some difficulty dealing with, depending on how fast the transitions happen and how long in shade/sunlight before next transition.
For me it's not a big enough issue and does not happen enough (maybe a few times a month) to warrant having to put the phone in safe mode. I just simply turn off adaptive brightness and adjust manually.
Interesting maybe some difference on the international version over the US ? My experience I hadn't had an issue on adaptive brightness which been the best I've had on my phones, I know my pixels weren't as accurate .
It works pretty good (IMO), but sometimes has a problem with some specific scenarios. I doubt it's vastly different across the different variants. Some of the limitations might not even ever be noticed by most.
Reactions: mustang7757
The short answer to your question is, no you cannot force maximum brightness on indefinitely. This is why to get maximum brightness the phone must also be set to adaptive. Samsung is trying to protect the screen. At maximum the risk of burn in is increased and as you can imagine Samsung doesn't want the headache of thousands of customers complaining of trying to warranty screens with burn-in or worse burnout so they make it only work when the phone can turn it down when it wants.
I assume that you've turned on Max brightness in the settings, if not here is a video to show you how.
There are several videos on how to activate this and how it works on YouTube. Most of the device reviewers I watched before buying the device mentioned this, how it worked and how to enable it. But, no, there is no way to force it on for ever and ever. Maybe if you changed your launcher, one like Nova, might have an override or setting that you can lock, but this might also damage your device.
oguk
