Kernel, Android System and Media server battery drain.
L Ronaldo
4
Hi,
the GSAM app on my HTC ONE M8 says that my app usage is higher than my screen and three of the main battery drainers are: Kernel (Android OS), Android System and System (Mediaserver).
I use my phone properly, charge it very well and have had 4 android phones. None were like this.
I have the latest firmware for the M8 (4.4.4).
My screen on time is not that good now, around 2-3 hours but when I first got the phone (3 months ago) it was 4-5 hours.
How do I reduce those 3 apps to make it last longer?
Having the exact same issue after updating to 4.4.4. Considerably less battery life with those things taking up the majority of power!
short of a hard reset there isnt really a way to fix that problem.
my Note 3 was having issues after its most recent update and after i hard reset it and re-loaded all my stuff its back to its original awesome ness.
you may try to wipe the cache partition and test that for a few days.. after every update i wipe cache and my M8 seems to be running just fine.
On the advice of someone else in another thread a cache partition wipe seems to have sorted the problem!
hiredbyskill
