[KERNEL - AOSP][HC3.1][UPDATE 6/2]Tiamat Xoom 1.4.4 "Full Throttle Baby @1.7Ghz"
Hi guys, Anyone know how to run this rom and mod the battery back to stock?
Also, Is there a version with the GPU overclock kernal already added?
I have a xoom 3g, flashed the tiamat rom, when back to flash the GPU OC tiamat kernel and ran into
2 wierd issues,
#1 a portrait version of the activation screen comes up at every reboot. with NO "SKip" option, you must hit home on every boot,.
#2 Wifi does not work. says "error" and all known fixes did not help, recopying all the .ko's etc..
Any ideas?
Thanks.
2 wierd issues,
Any ideas?
Thanks.
#1 - Did you do a data wipe via CWM? If so you need to restore your NANDROID backup, or reflash to your previous rom and then reflash without wiping data via CWM. I f you need to wipe data, do so from the Settings>Privacy menu.
#2 - Did you flash the boot image together with the kernel when you reflashed it? I also had a problem with wifi when trying to flash the led on boot image. You'll probably need to reflash the rom, apply the 3g fix and then just try flashing the GPU OC kernel without applying any of the boot.img files.
r3dpuk3
