[KERNEL][CM9][ICS] CAF-based 2.6.35 kernel for ICS-based roms
The kernel works fine. It's just that black screen bug, which app can i use for overclocking??
Sent from my LG-P505 using Android Central Forums
You don't need an external app to my knowledge
Settings - Performance - Processor. And you'll find it there
Sorry if my settings menu names are incorrect but I've messed up my Thrive again and I can't double check those...
Just wanted to report that newest build is 10 FASTER! AND BLACKSCREEN BUG FIXED!
Sent from my LG-P500 using Tapatalk 2
Tell me, should I make a seperate rom and kernel for Thrive, or should I keep it this way and let Thrive users flash current Rom and Kernel as it works for both phones?
I think it would be better to leave as is.
Reactions: _Arjen_
Yeah I think it's fine as it is, I have a Thrive and it already works perfectly so no point in just making extra work for yourself.
Before I flash this does anybody know if the new kernel lets you turn the phone off and start normally without the boot bug?
Ill test that as soon as i finish updating my apps.
Soon we will have the support for the new Linaro toolchain which should speed up the kernel!
It's being integrated by CM-team!
Reactions: Oathkeeper1212
It works! No blackscreen bug, No shutdown bug, runs amazing, and everything is perfect!
Also, I think it's a bug with the actual p500 rom, although its not even a big bug, the second boot screen after the lg logo is just a blank screen. Then it shows the new cyanogen mod mascot.
LG Logo>Blank Screen>Boot Animation with new Mascot.
Other than that, everything is godly!
:D
EDIT: Also Arjen, is the phoenix your main phone now or do you have a backup since your optimus one broke?
Thanks for all your awesome work!
:D
That black screen is because we removed CID splashscreen.
Maybe it will be introduced again.
My p500 was my play phone, also have an Optimus 2x and ordered a HTC One V. The phoenix I just bought to help you :D
Arjen, since you are now building nightlies for the p505 i was wondering if it's possible to build CWM as well? I hope its not too much too ask because our current CWM have the messed up colors. THANKS very much. I can finally put a wicked rom/kernel on my girls phone!
Ah, well thank you so much for helping us, I'll be sure to donate whenever I can get my paypal to work again. :)
EDIT: Does anyone know of a way of installing xloud and beats audio on ICS? Thanks. :D
Boot up is fixed .
brucestark2741
