[KERNEL][GB] GingerKernel v08.1 (OC) DOUBLE-TAPPING BUG FIXED!!!
Status
Not open for further replies.
Re: [KERNEL][GB/CM7] GingerKernel v04 (OC)
Successfully running this with gROM 1.1 I did wipe all caches before flashing. This runs awesome so far. No crazy sensitive screen yet.
i did wipe cache particion and deleted davlik cahce and still not rebooting. did u delete anything else?
So this DOES work with gROM 1.1? I am skeptical as to the screen issues, anyone care to shed some light on this matter?
can anyone else confirm that the screen issues have been eliminated? :)
Confirmed, no issues as we had with 03 on grom. Been running v4 all afternoon and evening, no issues, obviously smoother due to overclocking! Nice work!
Kernel running nicely on Opti-ROM. Good work Drewski! ;)
I have done several wipes and attempts to get this flashed on gRom, but each time I get a boot LG loop. What am I doing wrong. I have nandroid backups and have started from scratch, confused...
Sounds like an issue with compatibility. On the gROM thread it says DO NOT USE ANY OTHER KERNEL! No kernel is supported but the one it comes with... from what he has stated.
So what rom is it compatible with? Because it isn't that great on cm7 either. Iho v3.1 and xioniaredux are excellent but this one gives me issues!
Sent from my LG-LS670 using Tapatalk
Its running very nice on my optimus right now. Maybe dont use a backup and do a fresh install and try. I have not seen any issues with this kernel build.
The only real issue I've seen is having to tap the screen to activate. That probably has to do with the zvh version running on zvd. Its a little slower than previous tested kernels but it runs smooth. I'm sure drew will have a top notch kernel very soon.
Runs very smooth on ZVH on Opti-ROM. Great work as usual drew!
Yeah okay v04 epic failed on gROM 1.1.... my phone shut off like three times and when it finally lit back off it froze on the LG splash and straight up got stuck vibrating...... freaky.. i dirty flashed gROM 1.1 back onto it and im okay now. but dayum. my phone was doing some freaky stuff...
hmm wondering what is the defaut oc of this kernel? could be if its set too high so those of us that cannot go over 748mhz are getting the reboots?
Status
Jackwills2567
