Kies will not recognize my Galaxy SIII
well my phone is in a reboot loop
It sounds like you got an answer in another thread - is that your phone working correctly, or do you need further assistance?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Re: Kies will not recognize my Galaxy S3
hi. I use these steps but just "wondershare mobile go" recognize my phone and kise wont detect even connection!
Hello and welcome to the forums!
Which steps are you referring to? It would be helpful if you quoted the post in question.
Is your phone working normally?
Does Windows recognize your device?
Do you have the correct version of Kies installed?
I tried all the ways like removing battery or rooting but they didn't work. But when I just changed the USB cord and used a different one, it worked perfectly!
Letting Windows install drivers in USB debugging mode, disconnecting, disabling the debugging mode and reconnecting worked a treat.
Thank you - huge time saver.
rose1988
