Kies wont conect to phone............help!!!
plsss help me my problem
is my device's current firmware version is not supported to update via kies
but i can connect my phone to kies :'(:'(:'(:'(:'(:'(:'(:'(
I have the same issue. I am rooted so I do not know if that makes a difference or not. Every time I connect it just sits there and never connects but my wife's phone connects almost instantly.
This worked for a few times. But after a while the problem came back. The solution in my case was to enable "Developer options" without anything else. You will find that in Settings. Android version 4.1.2
I just installed the kies for windows 7 and ran it in admin rights. FRom there i connected it to my phone using stock power usb cable. When i connect the phone to the computer nothing happens and i just sit there waiting for something but nothing. I ninstalledd and reinstalled it but stil nothing. Also i ran thebuilt in tool and disconnected the cable, ran it, waited, restarted computer, then connected cable again but nothing. Looked around and found on samsung website a usb update file but still nothing.
PLEASE HELP I WANT JELLY BEAN
Sent from my GT-N8013 using Android Central Forums
Hi. I had the same problem i didn't know there are 2 types of cable, data cables and cables for charging (99p on ebay) try using the original 100% GENUINE SAMSUNG USB DATA CABLE.or you can get one from ebay but you must get the DATA cable type good luck. chris
Having tried KIES on two Win7 PCs & on XP PC the only solution that worked for me was ...
Turn on the Developer USB option.
This allows the drivers to install on the PC.
Then turn the Developer USB option off.
Thanks to previous posters for this invaluable tip.
Hi,
I have installed kies but when ever i connected my Samsung galaxy core 2 SM-G355H kies replies that your device does not support plz verify.
plz reply that what should i have to do to fix this problems.
thanx with regards:
MOhammad Talha
mathewsjamie138
