Kit kat update charging issue red X
ws6.baker
Active member
May 15, 2010
26
I just updated to kit kat and all was good until I plugged in my car charger. I have a griffin dual usb charger and samsung cable thathas always worked fine. Now when I plug it in I get a red X on the battery and when I unplug it it takes about 20 seconds for it to say it's not charging.
I am also experiencing this issue. It only occurs on 2a chargers where Settings - Battery reports Charging (AC) rather than Charging (USB) like when plugged into a lower amp USB port. One interesting thing to note is that if you power the S3 off and reboot, it will report (USB) under Battery Settings, but removing and reinserting the cable after booted, it will again show (AC) and the red X reappears; I've actually noted this behavior in the past, minus the red X, as I've found it was actually losing battery power faster than it could charge while using the device for GPS navigation, so I've always looked to make sure it was reporting (AC) and getting the higher charge-rate. I don't think it's a huge issue, since the battery is still charging with the red X, and found some posts indicating that it might simply mean that the device is running off (AC) power and not requiring any input from the battery.
So what charger would eliminate this?
A standard computer USB port puts out 500ma (half an amp), and you can find wall-chargers that range from 500ma to 2 amps+. You would need to use one that doesn't trigger the S3 switching to Charging (AC).
Ok so the s4 is 2 amp and I think the s3 is a 1.5. Is it getting too much charge with the 2? Only thing I cant figure out is it never did this prior to the kit kat update today.
Now im trying an apple 1 amp usb block and it still has red X
2 amp s4 works fine
2 amp samsung travel charger works fine
1 amp s3 works fine
1 amp apple red x
Griffin dual usb car charger red x
Same story here. The phone charges. That's all that matters to me.
AC App on SGS3
So even with the red X the phone is still charging?
I just updated to KitKat this morning and noticed the red X in my car.
Haven't tried it in the car, but with an external battery, any other than Samsung charger, etc., it still charges.
Tested in the car with my generic 2.1 amp charger and it still charges just as good even with the red x.
I'm thinking the Samsung charger and data cable provide a voltage sensing loop-back to the charger, assisting in the charging. Just a wag.
Since other chargers and cables may not have the function, an X is displayed.
AC App on SGS3
I have tried multiple auto chargers and even the Samsung cable. Red X on everything I have tried in the car. No problem with any combination of charger and cable on AC. As stated previously, the phone still charges as usual. I guess we'll have to live with it.
Im having the same issue on my car charger and stock charger.
Sent from my SCH-I535 using AC Forums mobile app
Hello everyone. Our phones are verizon's S3's. My phone and my wife's phone just got updated to the newest kitkat update and we are experiencing this red x in the battery icon with two of our 1A X5 Mobile brand chargers. The phone chargers were working fine before this update. We have another OEM samsung 750ma charger, a motorola 750ma car charger and a generic car charger, all of these work fine.
My wife's phone didn't charge overnight while showing the red X. The phone was a 26% this morning after charging all night. This sucks because we are down two home chargers now. Anyone know if I can revert back to the previous OS before kit kat? I'm sure they will come up with a fix sometime but I don't want to go get a couple of new chargers if I don't need to. Thanks.
Welcome to the forums!
I haven't seen anyone post about successfully downgrading from KitKat to Jelly Bean; there may be some information about that over on XDA though.
You could certainly try it yourself, but is it really worth all of the potential problems (up-to-and-including bricking your phone) to save $25 on a couple of new chargers?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
ZackS
