Knocking Sound while unlocking
sarapoep
Active member
Nov 11, 2013
32
I, as well as my parents got the G2 this weekend ( we love them ). However, I noticed when I tap to open on my Mom's phone there is a knocking sound, but there isn't one on mine. How do you get that sound to turn on and off?
Same with the clicks while typing? There is a clicking sound, how do you turn that on and off?
Thanks!!
go to menu,system settings,sound, then at the bottom there is touch feedback & system. there you can turn on the screenlock sound and the touch sounds
Thank you. For some reason it is still ticking while I text someone. I'm probably just missing something simple though.
I believe it's under Language and Input in the Settings menu, once there find LG Keyboard, then click the settings symbol to the right. Scroll down to the bottom and it says Additional Settings, open that and then uncheck "sound on keypress."
Why can't I find keyboard setting?
That did it! Thank you. Who would of thought it would hide in there? :)
adamgilcrist57890
