Kool-Aid--2.1--new leak!!!
Oh boy oh boy oh boy! I know what you mean. I mean, thank you guys and all for the work, but I miss the smell of Gumbo on my phone... dont hate.
I know what you mean,hopefully one of these days ill have enough skill/knowledge to make something close to a gumbo.;)
Flashed this last night. So far looks pretty good. apps2sd is working for me but I just check internal phone storage to see. I did hit the audio bug today. Always happens when I end one call then immediately make another call.
That sugar-free is really fast man. I think you took out the sugar and added some steroids:D
Seriously, of all the Roms based on the latest leak, this is by far the fastest one I have tried (and I have tried all)
Good work...you sure you not a psuedo for gb? :p
high and low
What is the main difference between high memory and low memory versions of the rom?
It does not have wifi tether where can I I find apk for it?
Also I tried to install both themes, did not see any difference. I just saved them on SD Card, rebooted in recovery and installed the zip. Am I doing it wrong way?
I flashed the ex.zip theme and it changed the launcher bar. Check out the images on the first.page.
The high/low has to do with the internal memory manager. You can get the wireless tehter apk here.
http://forum.androidcentral.com/htc-hero-roms-hacks/9535-add-ons-fixes-sprint-2-1-hero-leak.html
You only need to install one of the themes.It will only change the launcher and the focused application buttons to green or blue.
I've got and interest in trying out this rom. One question, is this as close to the stock leak as possible?
Other than what you have listed on the first post, have you done anything else?
That should be it. Its based off of the leak with tweaked memory (good thing) and rooted (good thing) and busybox (really good thing). What specifically would you be worried about? Its appearance would be identical to what Sprint releases, but it can be customized to how you want.
Thanks, I give you a thank but i don't see that button. Must have to have more time on this forum or something.
One other thing, should i wipe first?
that jus don't sound right...
Yes, you need 10 posts before you can thank me.
Always wipe before trying a new ROM, you may get it to work without, but the times I've tried has been nothing but bootloop.
dmflowsjalallodhi
