Kool-Aid--2.1--new leak!!!
My screen doesn't seem to shut off during a phone call. It does when using it for anything else though. I've been careful not to hit it with my cheek while talking also, anyone else have this issue? I'm running the rom with only the Espresso Theme and Voice keyboard flashed (wiped install).
I just checked, I don't have it. My screen goes off shortly after the call connects.
I just checked mine to make sure it works for me takes like 30sec. Do you have your screen time out set different then default?
So high/low is pretty much how aggressive the phone is freeing up memory, correct?
Recommendations? Benefits of one over the other?
Yeap. I have tested all of them,but not long enough to tell you if theres a big difference, i run high everyday.lol.
Works for me... just making sure before I decide to flash 'em. :) Thank you.
Just sucks setting everything up just the way I like it each time I flash a new ROM....
Keep getting a bootloop with "high" version... wiped and tried reflashing it a few times, any ideas?
Edit: Doing battery pull now....
Been trying to get this to work for an hour... I'm probably missing something simple... oh well.
Nandroid backup and I'll try it again tomorrow.
Which wipes are you doing? are you doing data/factory restore and dalvik (plus SD:EXT if you were using apps2sd)
hi there. just wanted to let you know im in the middle of trying this out :) currently running damages ruu edit, but having awake issues :(
tia, and ill report back shortly :)
Haha read your thread,hope you can stick around.:D
Make sure you wipe all three data,dalvik,ext like rufflez said and if you still have probs lets us know.
Hey beezy love your roms still using them. The new kool aid is very nice, if anybody is interested I have a theme that will work just fine on beezy over at xda if anybody wants to check it out. Theme. Keep up the great work!
Great work,throw up a thread so everyone see it.:D
Is anybody else getting FC'ed trying to open Settings? Also BT is dropping out. after a couple minutes with the headset on it drops then comes back..
benjifred645
