Koush's 2.1 Rom
  • Thread starter Thread starter Roy Aguilera
  • Start date Start date
yes i did its quick and painless just backup your sdcard it wipes it. Still have to go in and resize my Linux swap its to small for the rom I'm running
I did a couple restarts, it eventually turned back on. Weird!
I've experienced this phenomenon with Cyanogenmod. Usually the ROM starts restarting 2-4 times, I think it is a bootloop, and then it works fine.
Man that was easy. Love the fact that you can just move the apps from sd to internal and internal to sd. No need to redownload it all.
These guys are awesome.
Love this rom.:p
bunch of stats:
SD Card:
Total Space
14.29GB
Available Space
14.29GB
Unmount SD Card
Format SD Card
INternal Phone Storage
Available Space
188mb
it wont show up in your sdcard since its a new partition the phone wont recognize it as standard fat32 memory
It is not partitioned. I would try again.
Should have a SD card Secondary slot in there with a MB Total.
This is what I show.
i guess koushs rom has that listed the one im running doesnt so i can only see it when trying to partition it via another method
Hmm done it twice and this never showed up. I will try a third time. If not maybe I will just do it manually.
and its not partitioning your sdcard. did you add the linux swap if so try this script with gscript let me know if this works
swapon /dev/block/mmcblk0p3;
sysctl -w vm.swappiness=40
So I click on the Rom Manger>Partition>ext size I select 512mb>Swap Size 64mb>then go
It does its thing then when it comes back on nothing.
download gscript from the market and load the script i put on the window then try and see if it takes
if it says that the directory is not their then it did not create the swap partition
I think I know what the issue is. Are you over clocked?
Do this.
Hit download Rom>CyanogenMod>bekit Kernels>If you are not overclocked pick Stock, otherwise pick one. After this loads try repartitioning it.
That should solve your issue.
SBASF
