Lag - LockScreen
I wonder if a brand new SD card that is formatted from the phone would fix it. Maybe swapping from phone to phone for the last 5 years without formatting is the problem.
Could be... I just transferred it from my S4 without formatting, but on the other hand how many of people posting in different forums is actually not doing it ?.....I don't know, my S4 did not do that with the SD card I transferred from my S3.
This was really bothering me, but disabling Magazine helped fix it for me.
I have done that and got rid of the S Voice but even with the new phone still doing it. The only thing that made sense to me from the TMobile rep was that the Note3 goes into a deep sleep in order to save battery and therefore it takes a while to wake up all the way. Some how I think there should be a setting for how deep to allow the phone to into stand by ......
Just signed up to let you guys know, it was the memory card. I was having issues with the lock screen wake lag and when I removed my mem card it cleared it up. I've had the mini sd card through 3 cell phones so there could be a conflict with that.
The lag came back. Took out the SD card and it was gone again. Hopefully for good. Kinda sucks not having an SD card, but that lag was just ridiculous.
I already contacted Samsung about this ......maybe you guys need to do the same since no one oils a machine that it doesn't squeaks ...... perhaps they can fix this problem with an update ...............
How did you contact them, by which email or contact information? Has anyone else tried to use a different brand of mini SD card, like ScanDisk?
Mine was a samsung miniSD
I know this is a relatively old thread, but I figured I'd bring it back up to post my two cents.
I was having trouble with my phone not showing the unlock screen. I'd press the power button and after a couple of seconds would have to press it a couple more times before the screen finally came on. I removed the ADATA MicroSD card and it works perfectly now. I press the power button and the lock screens pops up as it should.
Definitely weird, but I too will be contacting Samsung about the problem.
Yeah same think for me. I haved try fews SD Cards, and some create the problem, some don't...
I had the same problem and it drove me crazy. at first, i thought it was a faulty Micro-SD card, and I bought another one (Samsung 32gb) but i still had lag. I removed the card completely and now I have zero lag. that's bad, I wanted to use that card (after coming from 2 Nexus phones without a option to have one).
Weird. Mine is slow when I lock and unlock repeatedly but quickly when left idle for a bit.
same thing happens to me. If I lock/unlock quickly i see the delay but if I leave the phone idle for 10-15 seconds it wakes up immediately
Sorry I didn't answer your question but I have been away from here for a while. I way I did it was that I went into the Samsung.com and I chatted lived with some one from support and advised them of the problem. I still have the transcripts from such conversation.
With my S5 i only experienced the slow unlock problem after i upgraded to Marshmallow. Fortunately my solution was easy : i de-activated my ALWAYS ON AMOLED app. Problem solved. Hope this helps someone.
wobblefix
