Launcher Pro, ADW, or touchwiz?
Starting to look at launcherpro the main reasons are the customizable dock and the landscape mode without having the keyboard out.
The one thing I feel I am missing is the Samsung Widget for the program manager, the one that lets you know if you have apps running in the background, when you tap it launches the stock task manager so you can end your app processes. Any widgets out there that I can do the same thing with LP?
If you hold the Home button you'll get the option to run the Task Manager. The widget only works under TW, as far as I can tell.
how does one change launchers once one is set as default? without dling home switcher.. i beleive there is a way no?
On your capacitive buttons select menu..
Then Applications
then menu on your capacitive buttons again.. Filter "ALL"
Select whichever Launcher your currently running. (Touchwiz I think show up as TW launcher) within the application info of your current running launcher..there is an area Launch by default. select the Clear Defaults button. Then exit out of application manager. and hit your capacitive Home key. You will then get a pop up prompt asking >complete actions using..
TW launcher
Home is stock android
Launcher Pro
be sure to select the check mark use by default for this action.
You can freely switch between any launcher you have on your phone. Voila
I want to mess with a new launcher one of these days but that darn touchwiz just has me hooked. :-)
Sent from my SPH-D700 using Tapatalk
Yes thanks, I was aware of that, I guess I just got accustomed to having that widget telling me to close my stuff. I like TW, would mostly like to see landscape without having to pull the keyboard (I do not think that is possible with current TW).
I had the dinc loved the sence ui.I own the x now am running lp now and am like sence who.I love the all the options there's so much you can do its carzy love
Sent from my DROIDX using Tapatalk
Just getting into all the customization for LP today, but that widget will be one of the things I will definitely miss from TW! :(
Heritagesa01
