launcher pro plus
All of them.
Calendar/Agenda Widget ? Shows you a calendar you can scroll through to switch months, and also lets you see your agenda for any particular day right within the widget.
what dock icons are those? they are sweet looking
Yea i want those.
Just did a google search for LP+ icons. Got them from various places, I dont remember hehe. They are out there though, just gotta look.
Reactions: packerbacker
Also the dock wallpaper is from guitar hero or something. Got it off of LPs forums.
All of them.
People Widget – To quickly access all your contacts, or just your favorites, or a particular group. (like the one found on Sense UIs)
How do you add and delete people?!:confused: ~ I just want a selected few.
When you go to add the widget you have the option to select a group. I use favorites. To add people to your favorite open their contact and you will see a little star in the corner. touch it and it should turn yellow. Then go back to the widget and refresh it.
Thanks DD. I figured this out, but then I wanted to just add/delete at will and couldn't. What about messages - how do you choose a selected group?
For the messages widget you cannot select a specific group to see messages from. That would be an awesome addition to the app. Maybe something to suggest to the developer of the app.
No where in particular. I put them in my images folder. What will happen is when you go to apply a custom icon it will take you into your gallery to select the icon. I would suggest putting the icons in their own folder on your SD card to make them easy to find.
You can set the launch bar across the bottom to scroll, so you can have more than the 5 shown at a time. Just scroll the bar left or right and you'll be able to add more icons to the launch bar.
Thanks! I'll have to play around with that.
Thanks- never really thought to try that. I'm going to do this later.
Yeah, it's also in the Launcher Pro Icons app, which I bought.
Thanks!
Problem
I can't seem to change my Facebook widget. I've seen some where they're completely transparent.
You could buy it just because it is an awesome launcher and the dev would appreciate your donation...
Sent from my SCH-I500 using Tapatalk
MichaelCrusan
