launcher pro plus
Is anyone else having an issue with Facebook not updating on the LP widget? It's been since yesterday on mine. Rebooted and restarted LP to no avail.
I just saw that the maker of LP had some errors in updating. He suggests that everyone update again to 0.8.1.1 - This should fix the problem.
I asked what you meant. Uninstall/reinstall? Or is there an update to download in the market? But I figured it out. Thanks.
thanks for the info guys! according to the link, you can also update via the market.
I purchased the paid version for the swipe action. When you swipe on the message icon, you'll get a list of unread SMS messages, swipe on the browser icon and get your bookmarks. It's a cool feature.
How do you do this? I can't find anything in the settings to make it do this.
Hold down the dock icon that you want, for instance the messaging icon, and a LP window will come up. From there select "Swipe gesture action". After that you should be able to swipe upwards on your messaging dock icon to view unread messages and if there are none, you will get a "no unread messages" popup.
I am running v0.8.1.1 and I still cannot login to facebook from the widget.
Go to Menu -> Preferences -> LP Widget Settings -> Facebook Widget -> Facebook Login. Try logging into there and then re-add the widget and it should work. Or at least that's what I had to do and it is working fine.
Is there a way for the bookmarks widget to detect bookmarks from third-party browsers, such as Dolphin? I don't want my stock browser's bookmarks appearing, especially the Verizon stuff that I can't delete.
You can set the launch bar across the bottom to scroll, so you can have more than the 5 shown at a time. Just scroll the bar left or right and you'll be able to add more icons to the launch bar.
Oh, that. Yes, I knew it could do that. That's definitely nice. :)
I finally upgraded to LP+ and can't figure how to change the look of the Calendar widget. I don't really like the grey color and want something that matches my wallpaper better.
Sent from my SCH-I500 using Tapatalk
Does anyone happen to know why when I click on my Launcher Pro contacts icon I get "Could not launch the requested activity". ????????:confused:
I have tried everything and can't get it to work.
Thanks
MichaelCrusan
