Leaked ICS ROM for AT&T Galaxy S II
I ran it for about a week, but just reverted back to UnNamed today. I really liked what it brought to the table and the visual elements (especially with the Apex launcher), but there were a couple things that nagged at me so I figured I'd give it some more time to cook. The biggest things were that it's unable to "deep sleep" when WiFi is enabled, which is a hit on the battery life; no BLN support in the kernel yet (I really got used to having that on UnNamed); and the contact photos were huge and stretched out with poor resolution.
Agreed, I wound up switching to SHOstock the wifi code is much more stable and has less bugs than the leak.
To be honest, the leak was quite disappointing, aside from the initial excitement I eventually got annoyed with the bugs.
I moved to ShoStock2 V1 and ......... omg! The rom is fantastic!! Super fast, quite efficient and looks amazing.
It has the perfect blend of TW and vanilla ICS. The apex launcher works perfectly, I have not run into any trouble so far and I have been using it for 3 days now. Shoman is really putting some fantastic work into this, also thanks to entropy for the kernel.
I would like to try CM9, but I am happy with this and I think I will wait for CM9 to come out officially, till then ShoStock it is!!
I was also unimpressed with the leak. Switch to Mystic's Pride v15 and couldn't be happier. Everything works and I haven't had any FC's or issues. Battery life if great. I don't even have to underclock it or keep the display dim to get a full day out of it.
i used this rom for 2 days max... it made my galaxy heat up, to the point i can put my coffee on top of it and the water will boil. (ok, maybe not, but my phone heat up very dramatically). Besides it wasn't so stable, since i had some issue with the bluetooth and WiFi connectivity.
Also a lot of force close, going around.
I will recommend to wait for the oficial release. Or try this leaked version if you like to suffer.
tuananh3105
